Saltar al contenido principal
Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement
Qué necesitas
  1. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: paso 1, imagen 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: paso 1, imagen 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Back Panel: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the two black rubber sheaths around the edges of the speaker.
    • Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
    • On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
  2. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 2, imagen 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 2, imagen 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 2, imagen 3 de 3
    • Use a JIS #0 screwdriver to remove the six screws to expose the motherboard.
  3. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 3, imagen 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 3, imagen 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 3, imagen 3 de 3
    • Using a pair of tweezers, pinch and pull the rubber fillings obstructing the screws.
  4. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 4, imagen 1 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 4, imagen 2 de 3 Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement: paso 4, imagen 3 de 3
    • Using a JIS #0 screwdriver, remove the 6 screws holding the backplate in.
    • Remove the back panel off of the device.
  5. Oontz Angle 3 ULTRA 3.5mm Auxiliary Port Replacement, Auxiliary Port: paso 5, imagen 1 de 1
    • With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
    • For more information on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
Conclusión
Una persona más ha completado esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 26
Todo El Tiempo: 253
