Introducción
If your Oontz Angle 3 ULTRA speaker is playing faulty audio with a 3.5mm auxiliary cable, you may need to replace your speaker’s 3.5mm auxiliary port. This replacement guide will walk you through replacing the 3.5mm auxiliary port of your Oontz Angle 3 ULTRA Bluetooth speaker. For this guide, you will need a plastic spudger, a Soldering Iron, and Solder Wick or a Solder Sucker. Follow this guide to learn how to solder and de-solder connections.
Warning: This guide is missing a crucial step between steps 4 and 5. The original author of this guide did not include the steps to remove the daughterboard from the device.
Qué necesitas
Herramienta utilizada en este paso:Tweezers$4.99
Remove the two black rubber sheaths around the edges of the speaker.
Under the symbol-marked sheath there is a white rubber covering for the buttons. Peel this away to reveal the panel underneath.
On two corners of its triangular face there is a small divot, which allows you to use your fingernails or a pair of tweezers to grip and peel away the covering.
With your solderwick and soldering iron, remove the solder at each point, and gently pull the 3.5mm port away from the motherboard with your tweezers.
Una persona más ha completado esta guía.
