Introducción
In this guide, some soldering is required when disconnecting the battery from the motherboard. If you are unfamiliar with soldering, watch Soldering Tutorial for Beginners, Five Easy Steps to familiarize yourself and to be able to correctly replace the battery.
Qué necesitas
Use the plastic opening tool to remove the rubber caps from each end of the speaker.
Begin by removing the bottom piece, revealing the inner compartment with the speaker cables and battery.
Remove two (2) 11.7mm Phillips #0 screws from each side of the speaker plate.
Remove speaker plate from the front of the battery.
14 personas más completaron esta guía.
25 comentarios
What is the kind of battery used? Thanks!
Hi Rodrigo, the Oontz Angle 3 uses a rechargeable 2200mAh lithium-ion battery. Happy Fixing!
can i upgrade it to 4300mah?
the one that I have has a "circuit board" attached to the battery. Is this what controls the recharging? If so, where do you get the battery with these?
Hi Rob,use soldering iron disconnect the circuit board which come with old battery you going to replace, and soldering iron the disconnected circuit board back onto your new battery. The so called circuit board is to protect the battery from over discharge or over charge. Hope this help.
