Introducción
Use this guide to fix your button pins if they are crooked.
  1. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place. Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Remove the top screw on the back panel. Remove the top screw on the back panel.
    • Remove the top screw on the back panel.
  3. Slide off the case to expose the internal components of the receiver. Slide off the case to expose the internal components of the receiver.
    • Slide off the case to expose the internal components of the receiver.
  4. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate. Unscrew the three screws on top of the face plate.
    • Unscrew the three screws on top of the face plate.
  5. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  6. Unscrew the one screw on the bottom of the front panel. Unscrew the one screw on the bottom of the front panel.
    • Unscrew the one screw on the bottom of the front panel.
  7. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force. Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  8. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws. On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
    • On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
  9. You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up. You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
    • You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
  10. You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken. You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
    • You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
  11. If any of the pins are bent use your pliers to bend the pins back into shape.
    • If any of the pins are bent use your pliers to bend the pins back into shape.
    • Take caution that too much force can break the button pins.
Conclusión
Ryan
Miembro Desde 13/04/10
90 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 27-92, Amido Spring 2010 Miembro de Cal Poly, Team 27-92, Amido Spring 2010
CPSU-AMIDO-S10S27G92
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 13
Todo El Tiempo: 3,948
