Saltar al contenido principal
Onkyo R-21 Laser Cleaning
Qué necesitas
  1. Onkyo R-21 Laser Cleaning, Remove plug and cover: paso 1, imagen 1 de 3 Onkyo R-21 Laser Cleaning, Remove plug and cover: paso 1, imagen 2 de 3 Onkyo R-21 Laser Cleaning, Remove plug and cover: paso 1, imagen 3 de 3
    • Remove the data cable from the amplifier by pulling during pressing the plug on both sides
    • Remove the 4 crews on the sides and the 3 screws on the back to remove the cover
  2. Onkyo R-21 Laser Cleaning: paso 2, imagen 1 de 3 Onkyo R-21 Laser Cleaning: paso 2, imagen 2 de 3 Onkyo R-21 Laser Cleaning: paso 2, imagen 3 de 3
    • The laser is located under the laser protection shield
    • You can move it closer by turning the white gear to get better access to clean it
  3. Onkyo R-21 Laser Cleaning, Clean the lense: paso 3, imagen 1 de 3 Onkyo R-21 Laser Cleaning, Clean the lense: paso 3, imagen 2 de 3 Onkyo R-21 Laser Cleaning, Clean the lense: paso 3, imagen 3 de 3
    • Take a microfiber cloth or any clean cloth which is lint-free
    • Wrap it around a flat screwdriver and soak it with high-percentage cleaning alcohol. I used 80% alcohol and it worked fine
    • Clean gently and carefully the lense
    • Turn the laser back to its standard position with the gearwheel
Conclusión
Chris Müller
Miembro Desde 09/25/18
367 Reputación
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 163
