Saltar al contenido principal
OnePlus X Battery Replacement
Qué necesitas
  1. OnePlus X Battery Replacement, Rear Panel: paso 1, imagen 1 de 2 OnePlus X Battery Replacement, Rear Panel: paso 1, imagen 2 de 2
    • Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
    • Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
    • Select "Power Off" on the screen to turn off the phone.
  2. OnePlus X Battery Replacement: paso 2, imagen 1 de 3 OnePlus X Battery Replacement: paso 2, imagen 2 de 3 OnePlus X Battery Replacement: paso 2, imagen 3 de 3
    • Insert a SIM card removal tool into the small hole located on the top right corner of the phone, just above the volume buttons.
    • If you do not have the original packaging or a SIM card removal tool, you may use a straightened out paperclip or something similar.
    • Push the removal tool into the hole and the tray should pop out.
    • Remove the SIM tray from the phone.
  3. OnePlus X Battery Replacement: paso 3, imagen 1 de 3 OnePlus X Battery Replacement: paso 3, imagen 2 de 3 OnePlus X Battery Replacement: paso 3, imagen 3 de 3
    • Put on heat-resistant gloves and place the phone on a surface that will not catch fire or melt.
    • Using a heat gun, apply slow and even heat to the edges of the back panel.
    • DO NOT stay on one spot for too long, the heat gun can damage the phone if the heat is applied to the same area for a long period of time.
    • While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
    • Carefully detach the back panel, using opening picks to hold the panel apart from the device.
    • Once most of the edges are separated from the device, attach a suction cup to the back panel.
  4. OnePlus X Battery Replacement: paso 4, imagen 1 de 3 OnePlus X Battery Replacement: paso 4, imagen 2 de 3 OnePlus X Battery Replacement: paso 4, imagen 3 de 3
    • Press the suction cup to the back panel to secure it.
    • With the help of the suction cup, pull up on the panel to completely detach it from the device.
    • Use the suction cup to safely remove the panel from the device. As you work around the panel's edges, the lingering heat may cause the remaining adhesive to reattach the panel to the device, be sure to lift the back panel before the glue has time to set back.
  5. OnePlus X Battery Replacement, Battery: paso 5, imagen 1 de 3 OnePlus X Battery Replacement, Battery: paso 5, imagen 2 de 3 OnePlus X Battery Replacement, Battery: paso 5, imagen 3 de 3
    • Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
    • Four (longer) PH000 screws
    • Three shorter PH000 screws
    • Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
    • There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
  6. OnePlus X Battery Replacement: paso 6, imagen 1 de 2 OnePlus X Battery Replacement: paso 6, imagen 2 de 2
    • Once the metal cover is removed, locate the battery connector wire, which clips into the motherboard.
    • Using a plastic spudger, gently pry on the clip to release it.
    • This will cut power to the phone, and prevent any power running to any of the components which is important while working on the phone.
  7. OnePlus X Battery Replacement: paso 7, imagen 1 de 3 OnePlus X Battery Replacement: paso 7, imagen 2 de 3 OnePlus X Battery Replacement: paso 7, imagen 3 de 3
    • On the battery, locate a clear tab. This will be used to pull the battery out.
    • Firmly grasp the clear tab and pull up and away from the phone to remove the battery.
    • Take your time during this step, as you do not want to apply too much force and damage the battery.
    • There is an adhesive underneath the battery so it might be useful to utilize the black plastic spudger to get between the battery and the phone to pry the battery up but be very careful not to break the ribbon cables underneath the battery.
    • Continue to pull slowly on the battery, until it is completely free from the phone.
Conclusión
27 personas más completaron esta guía.
Luis Castro
Miembro Desde 02/07/16
2,061 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 3-6, Wollert Spring 2016 Miembro de USF Tampa, Team 3-6, Wollert Spring 2016
USFT-WOLLERT-S16S3G6
2 Miembros
10 Guías creadas
8 comentarios
Thanks! This is cool! I didn't know I can replace my OnePlus X's battery :)
Antonius Harijanto - Contestar
how to stick back panel to the device again?
Sarthak Ahir - Contestar
Double sided adhesive
Maxime LUCAS -
Does someone know a good vendor for a new Battery for the OPX that sells in europ? I also want to change the battery after 2 1/2 years.
Thanks in advance =)
Det Maat - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 35
Todo El Tiempo: 33,988
