Introducción
Does your OnePlus 9 Pro have no sound playing? Is the audio distorted, crackling, or popping? Are your favorite songs missing that awesome bass line or high violin trills? The issue might be your bottom loudspeaker. Be sure to check if there is debris or dust in the speaker. If not, use this guide to replace the bottom loudspeaker of your OnePlus 9 Pro.
In step 3, you will use a heat gun. Use caution when handling high heat and follow the instructions on the packaging carefully.
Qué necesitas
Use one of the opening picks to remove the adhesive on the lower part of the wireless charging cable
Unplug the press connector ribbon cable attached to the flash module by inserting a spudger under the bottom edge and prying straight up.
Use an opening pick to remove the flash module by the camera.
Use a Phillips #000 screwdriver to remove the eleven 4.9 mm-long screws holding the motherboard cover to the phone.
Use an opening pick to pry off the motherboard cover.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
