Introducción
If the screen on your OnePlus 6 is cracked, shattered, or otherwise damaged, this guide will demonstrate how to replace it and get your phone back to its former glory.
If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
Discharge your battery to at least 25% capacity and turn off your device before beginning.
Qué necesitas
Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
Repeat until the back panel is fully released.
Grip the green tab connected to the battery and pull the battery directly up and out.
Use a Phillips #000 screwdriver to remove the eight screws.
Carefully lift the speaker up and out of the chassis.
Use a heat gun set to its lowest temperature, gently heat the perimeter of the screen to loosen the adhesive.
Wedge an opening pick between the screen and the chassis, then slide it around the entire perimeter of the screen to break the adhesive.
Gently pry the screen away from the chassis.
2 personas más completaron esta guía.
Un comentario
Works great, thank you very much. I changed the microphone with this instruction.
