Introducción
Follow this guide to remove and replace a defective fingerprint scanner/home button for the OnePlus 5. The fingerprint scanner is layered underneath the loudspeaker module and the daughterboard. The hardest part of the guide is getting the frame clips of the back cover free to access the internals of the phone.
Some guide images will show the battery already removed from the phone. You do not need to remove the battery for this procedure.
Qué necesitas
Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
Press firmly to eject the tray.
Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
Squeeze along the long edges of the phone to snap the remaining clips into place.
Use the point of a spudger to pry up and disconnect the battery connector from its socket.
Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
Use the point of a spudger the pry up and disconnect the fingerprint scanner connector from its socket on the daughterboard.
Herramienta utilizada en este paso:Electrical Tape in 6 Assorted Colors$7.99
Slide the flat end of a spudger underneath the tape covering the fingerprint scanner.
Lift up to pry and remove the tape.
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Una persona más ha completado esta guía.
8 comentarios
Is there an extra step involved so that the button stays countersunk in the new display? Mine seems to be slightly proud of the screen
Hi John,
If you may need to apply some new adhesive to the underside of the fingerprint sensor to hold it in place.
Hi,
I change the fingerprint but only works if don’t close the back cover, when I close the back cover the OS don’t detect the fingerprint sensor. Any idea?
Hey César,
It may be that something is shorting the fingerprint sensor. Did you replace the tape in step 24 with electrical tape?
Great news, finally I found the problem, the connector from daughter board to motherboard was disconnected but a lot of pins maked contact and the micro, and other electronics works but not the fingerprint sensor. I dissasembled the motherboard and pushed the connector from the flex cable to the socket, now all is working ok. Thanks for the response Arthur!
