Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
OnePlus 2 Screen Replacement
Qué necesitas
  1. OnePlus 2 Screen Replacement, SIM Card: paso 1, imagen 1 de 3 OnePlus 2 Screen Replacement, SIM Card: paso 1, imagen 2 de 3 OnePlus 2 Screen Replacement, SIM Card: paso 1, imagen 3 de 3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
    Pregunta a FixBot
  2. OnePlus 2 Screen Replacement: paso 2, imagen 1 de 3 OnePlus 2 Screen Replacement: paso 2, imagen 2 de 3 OnePlus 2 Screen Replacement: paso 2, imagen 3 de 3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
    Pregunta a FixBot
  3. OnePlus 2 Screen Replacement: paso 3, imagen 1 de 1
    • Remove the SIM card tray
    Pregunta a FixBot
  4. OnePlus 2 Screen Replacement, Battery: paso 4, imagen 1 de 3 OnePlus 2 Screen Replacement, Battery: paso 4, imagen 2 de 3 OnePlus 2 Screen Replacement, Battery: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
    Pregunta a FixBot
  5. OnePlus 2 Screen Replacement: paso 5, imagen 1 de 3 OnePlus 2 Screen Replacement: paso 5, imagen 2 de 3 OnePlus 2 Screen Replacement: paso 5, imagen 3 de 3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
    Pregunta a FixBot
  6. OnePlus 2 Screen Replacement: paso 6, imagen 1 de 3 OnePlus 2 Screen Replacement: paso 6, imagen 2 de 3 OnePlus 2 Screen Replacement: paso 6, imagen 3 de 3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
    Pregunta a FixBot
  7. OnePlus 2 Screen Replacement, Charging Port: paso 7, imagen 1 de 2 OnePlus 2 Screen Replacement, Charging Port: paso 7, imagen 2 de 2
    • Use the spudger tool to pry up the top connection of the charging port.
    • Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
    • Stop at the next connection.
    Pregunta a FixBot
  8. OnePlus 2 Screen Replacement: paso 8, imagen 1 de 3 OnePlus 2 Screen Replacement: paso 8, imagen 2 de 3 OnePlus 2 Screen Replacement: paso 8, imagen 3 de 3
    • Again, using the spudger tool, pry up the final 4 connections on the charging port
    • Again, just like before, slowly follow the cable with the spudger tool lifting it up from the adhesive backing.
    Pregunta a FixBot
  9. OnePlus 2 Screen Replacement: paso 9, imagen 1 de 3 OnePlus 2 Screen Replacement: paso 9, imagen 2 de 3 OnePlus 2 Screen Replacement: paso 9, imagen 3 de 3
    • Using the spudger tool on the bottom of the phone, push the charging part inward.
    • Once the charging port is free from the frame, use your fingers to remove the charging port the rest of the way.
    Pregunta a FixBot
  10. OnePlus 2 Screen Replacement, Screen: paso 10, imagen 1 de 3 OnePlus 2 Screen Replacement, Screen: paso 10, imagen 2 de 3 OnePlus 2 Screen Replacement, Screen: paso 10, imagen 3 de 3
    • Locate two connections at the bottom of the phone.
    • Using a spudger, carefully bend the connections up and towards the top of the phone.
    Pregunta a FixBot
  11. OnePlus 2 Screen Replacement: paso 11, imagen 1 de 2 OnePlus 2 Screen Replacement: paso 11, imagen 2 de 2
    • Locate connection left of the rear facing camera.
    • If black tape covers the connector, use tweezers to carefully peel it back.
    • Using a spudger, carefully pry the connector out and bend it towards the bottom of the phone.
    Pregunta a FixBot
  12. OnePlus 2 Screen Replacement: paso 12, imagen 1 de 1
    • Flip your phone so that the screen is facing up
    • Place a warm iOpener on the screen to heat up the adhesive holding the screen in place
    • Leave on for one minute
    Pregunta a FixBot
  13. OnePlus 2 Screen Replacement: paso 13, imagen 1 de 2 OnePlus 2 Screen Replacement: paso 13, imagen 2 de 2
    • Use a pick to carefully separate the screen and the rest of the phone.
    • Make sure to go around every edge and corner.
    Pregunta a FixBot
  14. OnePlus 2 Screen Replacement: paso 14, imagen 1 de 2 OnePlus 2 Screen Replacement: paso 14, imagen 2 de 2
    • Slowly separate the screen from the rest of the phone.
    Pregunta a FixBot
Conclusión
65 personas más completaron esta guía.
Kayla Williams
Miembro Desde 10/01/15
1,544 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-5, Maness Fall 2015 Miembro de Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
Miembros de 4
19 Guías creadas
29Guía Comentarios
Screen is available on internet but without frame and buttons. I bought one of those so the only pb i had was to separate capacitive buttons and fingerprint scanner from the screen. i had to separate the black plastic frame from the screen too. It takes me around 2 hours to do it but now my OP2 works with a brand new screen. Changing screen on OnePlus2 is doable and cost around 100€ but you have to be careful and patient.
cperverie - Contestar Compartir
Is the screen working properly??
Jagadeesh Sp - Contestar Compartir
It's the glue on the back of the screen or on the frame? Do you need to apply new glue?
krugern - Contestar Compartir
Hi, can you recommend the place where you bought your screen?
Tamara Diez - Contestar Compartir
You need glue when installing a new digitizer?
Steven - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 112
Todo El Tiempo: 60,852
