Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
OnePlus 2 Battery Replacement
Qué necesitas
  1. OnePlus 2 Battery Replacement, SIM Card: paso 1, imagen 1 de 3 OnePlus 2 Battery Replacement, SIM Card: paso 1, imagen 2 de 3 OnePlus 2 Battery Replacement, SIM Card: paso 1, imagen 3 de 3
    • Make sure that your phone is turned off before proceeding
    • Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
  2. OnePlus 2 Battery Replacement: paso 2, imagen 1 de 3 OnePlus 2 Battery Replacement: paso 2, imagen 2 de 3 OnePlus 2 Battery Replacement: paso 2, imagen 3 de 3
    • Locate the SIM card tray on the back of the phone
    • Use your thumb to gently slide out the tray
  3. OnePlus 2 Battery Replacement: paso 3, imagen 1 de 1
    • Remove the SIM card tray
  4. OnePlus 2 Battery Replacement, Battery: paso 4, imagen 1 de 3 OnePlus 2 Battery Replacement, Battery: paso 4, imagen 2 de 3 OnePlus 2 Battery Replacement, Battery: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Find and carefully remove all 6 rubber screw covers with the tweezers.
    • Unscrew all 18 screws from the mid frame.
  5. OnePlus 2 Battery Replacement: paso 5, imagen 1 de 3 OnePlus 2 Battery Replacement: paso 5, imagen 2 de 3 OnePlus 2 Battery Replacement: paso 5, imagen 3 de 3
    • Carefully pry up the mid frame from the back of the phone with the plastic opening tools.
    • Slowly work your way around the phone releasing all the clips that hold the frame in place.
  6. OnePlus 2 Battery Replacement: paso 6, imagen 1 de 3 OnePlus 2 Battery Replacement: paso 6, imagen 2 de 3 OnePlus 2 Battery Replacement: paso 6, imagen 3 de 3
    • Using the spudger tool, pry the battery up from the adhesive.
    • Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
Conclusión
99 personas más completaron esta guía.
Kayla Williams
Miembro Desde 10/01/15
1,544 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-5, Maness Fall 2015 Miembro de Cal Poly, Team 4-5, Maness Fall 2015
CPSU-MANESS-F15S4G5
Miembros de 4
19 Guías creadas
21Guía Comentarios
Nice to see that, thanx !
But do you know where it's possible to buy a new battery ?
I see "designed by oneplus" on it and I'm not sure it would be easy to find one on internet usual stores.
Fred Hamel - Contestar Compartir
You can look up a oneplus service center in your country/locality by going to your country's version of the oneplus site. There in the support -->Contact Us, you will find a list of places(service centers) you can go for repairs and a price list of all the parts and the service to replace them. Not sure if this works for every country, worked for me.
Zuke Denvar - Compartir
this is not a full help.. how do we suppose to buy official battery for onelus2?
and this method would be great if you upload a video in full detail without missing any point.
so, please do that. Thanks in advance!
shahfaishalkhan - Contestar Compartir
Use google.com and search for BLP597 that's the itemnumber of the battery in question. There are plenty of sellers available.
Markus Flaig - Compartir
any good battery for oneplus 2? i wanna buy a new battery for oneplus 2 can you please suggest me good battery for it? please tell me i really need it asap.
Thank you!!
Aalok Kumar - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 28
Ultimos 30 días: 110
Todo El Tiempo: 54,715
