Saltar al contenido principal
OneLink Safe and Sound Battery Replacement
Qué necesitas
  1. OneLink Safe and Sound Battery Replacement, Cover: paso 1, imagen 1 de 2 OneLink Safe and Sound Battery Replacement, Cover: paso 1, imagen 2 de 2
    • Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
    • Remove plastic rim.
  2. OneLink Safe and Sound Battery Replacement: paso 2, imagen 1 de 2 OneLink Safe and Sound Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove nine screws from the top of the device.
  3. OneLink Safe and Sound Battery Replacement: paso 3, imagen 1 de 2 OneLink Safe and Sound Battery Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Don't yank or pull the lid off as there are ribbons and cables connecting the top of the device to the motherboard. They need to be disconnected before the top is removed.
    • Use tweezers or a spudger to disconnect the ribbon from the motherboard.
  4. OneLink Safe and Sound Battery Replacement: paso 4, imagen 1 de 1
    • Use tweezers to unplug the speaker cable from the motherboard.
  5. OneLink Safe and Sound Battery Replacement: paso 5, imagen 1 de 2 OneLink Safe and Sound Battery Replacement: paso 5, imagen 2 de 2
    • Use the plastic opening tool to remove the microphone connection from the motherboard.
    • Remove the top of the device.
  6. OneLink Safe and Sound Battery Replacement, Battery: paso 6, imagen 1 de 1
    • Use the plastic opening tool to disconnect the cable from the motherboard.
  7. OneLink Safe and Sound Battery Replacement: paso 7, imagen 1 de 2 OneLink Safe and Sound Battery Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the single screw securing the plastic battery cage.
  8. OneLink Safe and Sound Battery Replacement: paso 8, imagen 1 de 2 OneLink Safe and Sound Battery Replacement: paso 8, imagen 2 de 2
    • Remove the plastic cage holding the battery in place.
    • Remove the battery from the device.
Conclusión
Una persona más ha completado esta guía.
Arianna Roberts
Miembro Desde 11/10/22
639 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 2-2, Petersen Fall 2022 Miembro de UMass Dartmouth, Team 2-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G2
3 Miembros
6 Guías creadas
4 comentarios
Where do I get this battery replacement
Dallas Massey - Contestar
people that has purchased this product. If the battery goes dead where can someone purchase a replacement battery from and what size battery would they need
Pamela Wright - Contestar
Is there a P/N for the battery pack or it needs to be bought individually and then put together
Thank you
Jose Chocano Felice - Contestar
Bought a 2CR17335A-WK17 battery pack from Amazon for $15 plus tax. Just had to splice wires to existing connector to match the motherboard. So far so good. Had a 5 chirp tone every 2 minutes advising battery had come to end of life. Not sure why a 10 year battery only lasted 3 years from the manufacturing date but oh well.
Mario Garcia - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 30
Ultimos 30 días: 64
Todo El Tiempo: 1,238
