Saltar al contenido principal
One Education Infinity Touchpad Replacement
Qué necesitas
  1. One Education Infinity Touchpad Replacement, Back Case: paso 1, imagen 1 de 3 One Education Infinity Touchpad Replacement, Back Case: paso 1, imagen 2 de 3 One Education Infinity Touchpad Replacement, Back Case: paso 1, imagen 3 de 3
    • Always power off your device before beginning disassembly.
    • Remove the screw covers and rubber feet from the bottom of the laptop with a metal spudger.
  2. One Education Infinity Touchpad Replacement: paso 2, imagen 1 de 2 One Education Infinity Touchpad Replacement: paso 2, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the sixteen 5.0 mm black screws from the back panel.
  3. One Education Infinity Touchpad Replacement: paso 3, imagen 1 de 3 One Education Infinity Touchpad Replacement: paso 3, imagen 2 de 3 One Education Infinity Touchpad Replacement: paso 3, imagen 3 de 3
    • Using the iFixit plastic opening tool or spudger, start near the white hinge of the device and lift along the outer edges of the device until all clips are released.
    • Lift the back case off of the device.
    • Removing the back may create a loud snapping noise.
  4. One Education Infinity Touchpad Replacement, Battery: paso 4, imagen 1 de 3 One Education Infinity Touchpad Replacement, Battery: paso 4, imagen 2 de 3 One Education Infinity Touchpad Replacement, Battery: paso 4, imagen 3 de 3
    • There may be black tape inside your device covering components or holding down wires. This tape is unimportant for the function of the device, and can be removed.
    • Carefully wiggle the battery cable to the right and out of the port with a plastic spudger.
  5. One Education Infinity Touchpad Replacement: paso 5, imagen 1 de 3 One Education Infinity Touchpad Replacement: paso 5, imagen 2 de 3 One Education Infinity Touchpad Replacement: paso 5, imagen 3 de 3
    • Wedge a plastic spudger underneath the battery from the upper edge and slide it carefully along the length of the battery to separate it from the case.
    • There is a mild adhesive holding down the battery. Take care not to puncture or excessively bend the battery while freeing it from the adhesive.
    • Lift the battery out from the internal case.
  6. One Education Infinity Touchpad Replacement, Solid State Drive: paso 6, imagen 1 de 3 One Education Infinity Touchpad Replacement, Solid State Drive: paso 6, imagen 2 de 3 One Education Infinity Touchpad Replacement, Solid State Drive: paso 6, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the single 2mm black screw from the SSD.
  7. One Education Infinity Touchpad Replacement: paso 7, imagen 1 de 3 One Education Infinity Touchpad Replacement: paso 7, imagen 2 de 3 One Education Infinity Touchpad Replacement: paso 7, imagen 3 de 3
    • Grab the SSD with your fingers and slide it slowly to the right and out of its port.
  8. One Education Infinity Touchpad Replacement, Motherboard: paso 8, imagen 1 de 2 One Education Infinity Touchpad Replacement, Motherboard: paso 8, imagen 2 de 2
    • Using your fingers, carefully pull the two ribbon cable locking clips out from their ports.
  9. One Education Infinity Touchpad Replacement: paso 9, imagen 1 de 1
    • Using your fingers, carefully lift up the black tab and then unplug the gold ribbon cable.
  10. One Education Infinity Touchpad Replacement: paso 10, imagen 1 de 1
    • Using a spudger, carefully unplug the black and grey wires by popping them up off the wireless card.
  11. One Education Infinity Touchpad Replacement: paso 11, imagen 1 de 1
    • Using your fingers, carefully unplug the two speaker wires from the motherboard.
  12. One Education Infinity Touchpad Replacement: paso 12, imagen 1 de 2 One Education Infinity Touchpad Replacement: paso 12, imagen 2 de 2
    • Using your fingers or an iFixit opening tool, carefully lift the black tab on top of the ZIF connector and remove the ribbon cable.
  13. One Education Infinity Touchpad Replacement: paso 13, imagen 1 de 1
    • Using your fingers, carefully lift up the black tab and then unplug the blue ribbon cable.
  14. One Education Infinity Touchpad Replacement: paso 14, imagen 1 de 2 One Education Infinity Touchpad Replacement: paso 14, imagen 2 de 2
    • Using a Phillips #00 screwdriver, remove the single 4 mm silver screw from beneath the ribbon cable.
    • Using a Phillips #00 screwdriver, remove the two 2.5 mm black screws.
    • Using your fingers, carefully lift the motherboard out of the internal panel.
  15. One Education Infinity Touchpad Replacement, Touchpad: paso 15, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the four 2mm silver screws.
  16. One Education Infinity Touchpad Replacement: paso 16, imagen 1 de 2 One Education Infinity Touchpad Replacement: paso 16, imagen 2 de 2
    • Peel back the black tape.
    • Using your fingers, carefully lift the metal plate out of the internal panel.
  17. One Education Infinity Touchpad Replacement: paso 17, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two 2mm silver screws.
  18. One Education Infinity Touchpad Replacement: paso 18, imagen 1 de 2 One Education Infinity Touchpad Replacement: paso 18, imagen 2 de 2
    • Using your fingers, carefully lift the touch-pad out of the internal panel.
Conclusión
Jason Childers
Miembro Desde 10/10/19
109 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S11-G4, Regan Fall 2019 Miembro de Cal Poly, Team S11-G4, Regan Fall 2019
CPSU-REGAN-F19S11G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 220
