Saltar al contenido principal
Onda V701 Front- Facing Camera Replacement
Qué necesitas
  1. Onda V701 Front- Facing Camera Replacement, Back Panel: paso 1, imagen 1 de 3 Onda V701 Front- Facing Camera Replacement, Back Panel: paso 1, imagen 2 de 3 Onda V701 Front- Facing Camera Replacement, Back Panel: paso 1, imagen 3 de 3
    • Ensure device is powered off before disassembly.
    • Remove the 4 rubber screw plugs using a spudger.
  2. Onda V701 Front- Facing Camera Replacement: paso 2, imagen 1 de 3 Onda V701 Front- Facing Camera Replacement: paso 2, imagen 2 de 3 Onda V701 Front- Facing Camera Replacement: paso 2, imagen 3 de 3
    • Remove the four 4.8mm mounting screws using a PH00 screwdriver.
  3. Onda V701 Front- Facing Camera Replacement: paso 3, imagen 1 de 2 Onda V701 Front- Facing Camera Replacement: paso 3, imagen 2 de 2
    • Starting at one corner, gently pry the back panel assembly from the screen assembly using two plastic opening tools.
    • Slide the opening tools around the perimeter of the device to separate the back panel assembly from the screen assembly.
  4. Onda V701 Front- Facing Camera Replacement: paso 4, imagen 1 de 2 Onda V701 Front- Facing Camera Replacement: paso 4, imagen 2 de 2
    • Gently lift the screen assembly away from the back cover assembly.
    • Be careful when separating the two pieces as the screen assembly is still connected to the mother board by two ribbon cables.
  5. Onda V701 Front- Facing Camera Replacement: paso 5, imagen 1 de 3 Onda V701 Front- Facing Camera Replacement: paso 5, imagen 2 de 3 Onda V701 Front- Facing Camera Replacement: paso 5, imagen 3 de 3
    • Disconnect the two ribbon connectors by flipping the gray tabs up with a fingernail or a spudger.
    • Remove the ribbon cables.
  6. Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: paso 6, imagen 1 de 2 Onda V701 Front- Facing Camera Replacement, Front- Facing Camera: paso 6, imagen 2 de 2
    • Gently pry the front-facing camera away from the back panel using a spudger.
  7. Onda V701 Front- Facing Camera Replacement: paso 7, imagen 1 de 2 Onda V701 Front- Facing Camera Replacement: paso 7, imagen 2 de 2
    • Flip the gray locking tab of the ribbon connector up using a spudger.
    • Remove the ribbon cable from the connector.
  8. Onda V701 Front- Facing Camera Replacement: paso 8, imagen 1 de 1
    • Remove the front-facing camera assembly.
Conclusión
Bradley Huber
Miembro Desde 03/11/15
366 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 9
Todo El Tiempo: 255
