Saltar al contenido principal
OnHub Speaker Grille Replacement
Qué necesitas
  1. OnHub Speaker Grille Replacement, Speaker Grille: paso 1, imagen 1 de 2 OnHub Speaker Grille Replacement, Speaker Grille: paso 1, imagen 2 de 2
    • Make sure the device is unplugged before proceeding with the disassembly.
    • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
  2. OnHub Speaker Grille Replacement: paso 2, imagen 1 de 1
    • Place the plastic opening tool under the speaker grille, and just above the light ring.
    • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
  3. OnHub Speaker Grille Replacement: paso 3, imagen 1 de 2 OnHub Speaker Grille Replacement: paso 3, imagen 2 de 2
    • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
    • There is a delicate wire connection to the antenna that is easily broken if not careful.
Conclusión
3 personas más completaron esta guía.
Equipo
USF Tampa, Team 3-3, Sullivan Spring 2016 Miembro de USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 268
