Saltar al contenido principal
Omaker M4 Motherboard Replacement
Qué necesitas
  1. Omaker M4 Motherboard Replacement, Back Case: paso 1, imagen 1 de 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Motherboard Replacement: paso 2, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Motherboard Replacement: paso 3, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Motherboard Replacement: paso 4, imagen 1 de 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Motherboard Replacement: paso 5, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 2 Omaker M4 Motherboard Replacement, Motherboard: paso 6, imagen 2 de 2
    • Remove the mic wire by carefully pulling the plug out of the socket.
  7. Omaker M4 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the speaker wire by carefully pulling the plug out of the socket on the motherboard.
  8. Omaker M4 Motherboard Replacement: paso 8, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 8, imagen 2 de 2
    • Use Phillips PH00 screwdriver to remove the three screws holding the motherboard in place.
  9. Omaker M4 Motherboard Replacement: paso 9, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 9, imagen 2 de 2
    • Remove the screws using the screwdriver.
    • Since the screws that hold the motherboard in place are smaller, the screwdriver is able to pick them up.
  10. Omaker M4 Motherboard Replacement: paso 10, imagen 1 de 2 Omaker M4 Motherboard Replacement: paso 10, imagen 2 de 2
    • Carefully remove the motherboard with your hand by lifting it from the device.
Conclusión
2 personas más completaron esta guía.
[deleted]
Miembro Desde 02/17/16
679 Reputación
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,174
