Saltar al contenido principal
Omaker M4 Battery Replacement
Qué necesitas
  1. Omaker M4 Battery Replacement, Back Case: paso 1, imagen 1 de 1
    • Flip the device over so the front of the speaker is facing down. Make sure to place the speaker on a flat surface
  2. Omaker M4 Battery Replacement: paso 2, imagen 1 de 2 Omaker M4 Battery Replacement: paso 2, imagen 2 de 2
    • Use a T6 Torx screwdriver to remove the four 9mm screws from the back of the device.
  3. Omaker M4 Battery Replacement: paso 3, imagen 1 de 2 Omaker M4 Battery Replacement: paso 3, imagen 2 de 2
    • Use a magnet to remove the screws after unscrewing them and place them aside.
  4. Omaker M4 Battery Replacement: paso 4, imagen 1 de 1
    • Carefully remove the back cover without breaking the battery wire.
  5. Omaker M4 Battery Replacement: paso 5, imagen 1 de 2 Omaker M4 Battery Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Remove the end of the battery connection from the motherboard by holding the end of the wire and carefully pulling it out of the socket using tweezers.
    • The battery is still attached to the back cover.
  6. Omaker M4 Battery Replacement, Battery: paso 6, imagen 1 de 3 Omaker M4 Battery Replacement, Battery: paso 6, imagen 2 de 3 Omaker M4 Battery Replacement, Battery: paso 6, imagen 3 de 3
    • Use the metal spudger to carefully pry along the entire side of the battery from its connecting tape on the back cover.
Conclusión
3 personas más completaron esta guía.
Carlos Pernia
Miembro Desde 02/10/16
170 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 2-2, Sullivan Spring 2016 Miembro de USF Tampa, Team 2-2, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G2
3 Miembros
2 Guías creadas
Un comentario
What battery is required for this though? Is it easily found on amazon?
Mohsin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 1,357
