Introducción
This guide will show you how to remove and replace the lens box unit on the Olympus VR-350.
Qué necesitas
Remove the two 4mm screws from each side of the camera with a Phillips PH000 screwdriver.
Using the Phillips PH000 screwdriver, remove the 4mm screw from the bottom left corner of the button plate located under the button membrane.
Remove the metal plate that was underneath the LCD screen by removing the four 4 mm screws with the Phillips PH000 screwdriver.
5 personas más completaron esta guía.
Un comentario
Worked for a SH-21, with a couple of extra screws to remove. Thank you!
