Saltar al contenido principal
Olympus Tough TG-1 Screen Replacement
Qué necesitas
  1. Olympus Tough TG-1 Screen Replacement, Clip Side Repair: paso 1, imagen 1 de 2 Olympus Tough TG-1 Screen Replacement, Clip Side Repair: paso 1, imagen 2 de 2
    • Remove both 6 mm screws from the clip side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • If one of more of the clips appear to be broken, the back plate might need to be replaced.
  2. Olympus Tough TG-1 Screen Replacement, Top of Camera: paso 2, imagen 1 de 1
    • The top of the camera does not contain screws. You do not need to remove anything from the top of the camera.
  3. Olympus Tough TG-1 Screen Replacement, Plug Side: paso 3, imagen 1 de 3 Olympus Tough TG-1 Screen Replacement, Plug Side: paso 3, imagen 2 de 3 Olympus Tough TG-1 Screen Replacement, Plug Side: paso 3, imagen 3 de 3
    • Remove the two 5 mm screws on the side of the camera with the plug.
    • Open the compartment door and remove both 6 cm screws inside of the compartment door. This will allow you to remove the tan piece held by the screws.
  4. Olympus Tough TG-1 Screen Replacement, Bottom: paso 4, imagen 1 de 1
    • Turn the camera so that you are looking at the bottom of the camera.
    • Remove the two 4 mm screws from the bottom of the camera.
    • The screws are different. The rear screw is has an unthreaded shank to locate the outer shell while screwing into the inner frame.
  5. Olympus Tough TG-1 Screen Replacement, Front Panel: paso 5, imagen 1 de 3 Olympus Tough TG-1 Screen Replacement, Front Panel: paso 5, imagen 2 de 3 Olympus Tough TG-1 Screen Replacement, Front Panel: paso 5, imagen 3 de 3
    • Use the plastic opening tool to remove both components of the front panel. This includes the black part on the outside of the front panel and the main silver panel.
    • Once every screw and panel is removed, you can replace the backplate to make your camera weatherproof again.
  6. Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: paso 6, imagen 1 de 3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: paso 6, imagen 2 de 3 Olympus Tough TG-1 Screen Replacement, Opening the Internal Case: paso 6, imagen 3 de 3
    • Using the plastic opening tools, carefully open the case.
    • Do not tear the white circuit ribbon.
  7. Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: paso 7, imagen 1 de 3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: paso 7, imagen 2 de 3 Olympus Tough TG-1 Screen Replacement, Opening the Screen's Protective Cover: paso 7, imagen 3 de 3
    • Using the screwdriver, remove the ten 3mm anchor screws.
    • Using the plastic opening tool, open the protective cover so that the screen is exposed.
  8. Olympus Tough TG-1 Screen Replacement, Unclipping the Screen from the Circuit Ribbon: paso 8, imagen 1 de 1
    • Carefully unclip the screen from its circuit ribbon.
Conclusión
Emily Gensch
Miembro Desde 01/21/15
116 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 4-6, Brown Winter 2015 Miembro de USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 2,324
