Saltar al contenido principal
Olympus TG-820 iHS Locking Mechanism Replacement
Qué necesitas
  1. Olympus TG-820 iHS Locking Mechanism Replacement, Battery: paso 1, imagen 1 de 1
    • Orient camera to look directly at battery compartment side as shown.
  2. Olympus TG-820 iHS Locking Mechanism Replacement: paso 2, imagen 1 de 3 Olympus TG-820 iHS Locking Mechanism Replacement: paso 2, imagen 2 de 3 Olympus TG-820 iHS Locking Mechanism Replacement: paso 2, imagen 3 de 3
    • Locate the two latches on the battery compartment.
    • First, move the "lock" switch left to reveal red indicator.
    • Next, move the "cover latch" switch downward to reveal red indicator.
    • You have to move the switches in that order for the compartment to unlatch.
  3. Olympus TG-820 iHS Locking Mechanism Replacement: paso 3, imagen 1 de 2 Olympus TG-820 iHS Locking Mechanism Replacement: paso 3, imagen 2 de 2
    • Allow the battery compartment latch to completely open.
    • Insert battery with the writing face up.
    • The bigger slot is for the battery. The smaller slot is for the memory card.
    • Battery not shown.
  4. Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: paso 4, imagen 1 de 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: paso 4, imagen 2 de 3 Olympus TG-820 iHS Locking Mechanism Replacement, Locking Mechanism: paso 4, imagen 3 de 3
    • Locate and remove the 4.7mm Phillips #000 screw on the back side of the battery compartment locking mechanism.
    • Locate and remove the 4.7mm Phillips #000 screw on the front side of the battery compartment locking mechanism.
  5. Olympus TG-820 iHS Locking Mechanism Replacement: paso 5, imagen 1 de 1
    • Locate the two screws on the side of the battery compartment.
    • Remove the two 4.85mm Phillips #000 screws.
  6. Olympus TG-820 iHS Locking Mechanism Replacement: paso 6, imagen 1 de 2 Olympus TG-820 iHS Locking Mechanism Replacement: paso 6, imagen 2 de 2
    • Once all 4 screws are out, the back panel of the battery compartment will come off.
    • The entire battery compartment cover will also detach from the camera.
Conclusión
Larissa Knight
Miembro Desde 03/21/16
549 Reputación
5 Guías creadas
Equipo
Clemson, Team 7-2, Benson Spring 2016 Miembro de Clemson, Team 7-2, Benson Spring 2016
CLEM-BENSON-S16S7G2
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 442
