Saltar al contenido principal
Olympus Stylus Tough-8010 Side Panel Replacement
Qué necesitas
  1. Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: paso 1, imagen 1 de 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: paso 1, imagen 2 de 3 Olympus Stylus Tough-8010 Side Panel Replacement, Side Panel: paso 1, imagen 3 de 3
    • Remove the three screws (3.2mm) from the front panel using a T-6 screwdriver.
    • Take off the smaller front panel cover.
    • Carefully remove the larger front cover.
  2. Olympus Stylus Tough-8010 Side Panel Replacement: paso 2, imagen 1 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 2, imagen 2 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 2, imagen 3 de 3
    • Remove the top two screws (4.1mm) using a #000 Phillips head screwdriver.
    • Remove the two screws (7.9mm) near the control pad. Set metal connector aside.
    • Remove the side panel casing.
  3. Olympus Stylus Tough-8010 Side Panel Replacement: paso 3, imagen 1 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 3, imagen 2 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 3, imagen 3 de 3
    • Using a #000 Philips head screwdriver, remove the two screws (4.1mm) on the right side of the camera.
    • Remove the two screws (4.1mm) from the bottom of the camera.
    • Remove the single screw (3.2mm) from the front of the camera.
  4. Olympus Stylus Tough-8010 Side Panel Replacement: paso 4, imagen 1 de 2 Olympus Stylus Tough-8010 Side Panel Replacement: paso 4, imagen 2 de 2
    • Carefully remove the front panel piece.
    • Remove the screw (7.9mm) from the bottom left hand corner using a #000 Phillips head screwdriver.
  5. Olympus Stylus Tough-8010 Side Panel Replacement: paso 5, imagen 1 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 5, imagen 2 de 3 Olympus Stylus Tough-8010 Side Panel Replacement: paso 5, imagen 3 de 3
    • Slightly bend the metal that is covering the side panel axle.
    • Using a paperclip, completely push out the metal bar that holds the side panel to the camera.
    • Remove the side panel door.
Conclusión
James G Payne
Miembro Desde 03/23/15
225 Reputación
2 Guías creadas
Equipo
Baylor, Team 7-15, Williams Spring 2015 Miembro de Baylor, Team 7-15, Williams Spring 2015
BU-WILLIAMS-S15S7G15
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 10
Todo El Tiempo: 345
