Saltar al contenido principal
Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement
Qué necesitas
  1. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: paso 1, imagen 1 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: paso 1, imagen 2 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement, Battery and Connector Seals: paso 1, imagen 3 de 3
    • Locate the battery/card cover on the bottom of the camera. .
    • Slide the tab labeled lock to show orange.
    • Slide the battery/card cover lock to revile orange and the door will spring open.
  2. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 2, imagen 1 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 2, imagen 2 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 2, imagen 3 de 3
    • Remove the 2 Phillips #00 screws on the inner battery door.
    • Use a spudger to release the seal and metal clip.
    • Replace the seal.
  3. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 3, imagen 1 de 2 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 3, imagen 2 de 2
    • Locate the connector cover on the side of the camera.
    • Slide the connector cover lock to revile orange and the door will spring open.
  4. Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 4, imagen 1 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 4, imagen 2 de 3 Olympus Stylus Tough TG-2 iHS Battery and Connector Seals Replacement: paso 4, imagen 3 de 3
    • Remove the 2 Phillips #00 screws on the inner connector door.
    • Use a spudger to release the seal, the clear plastic piece, and the metal piece.
Conclusión
Una persona más ha completado esta guía.
3 comentarios
Where can I get the seals?
Ahmed - Contestar
I have the same question. Where can I buy the seals? Olymus service man told me it is not possible to buy, and that I have to send TG-2 to service and pay about 100$.
adan - Contestar
OK. Great instructions. I think I could do this, but where do I get the seals?
Steve Tobin - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 13
Todo El Tiempo: 2,047
