Saltar al contenido principal
Olympus Stylus Tough 6020 LCD Replacement
Qué necesitas
  1. Olympus Stylus Tough 6020 LCD Replacement, Battery: paso 1, imagen 1 de 1
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: paso 2, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: paso 2, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement, Bottom Plating: paso 2, imagen 3 de 3
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Olympus Stylus Tough 6020 LCD Replacement, Top Plating: paso 3, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement, Top Plating: paso 3, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement, Top Plating: paso 3, imagen 3 de 3
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Olympus Stylus Tough 6020 LCD Replacement, Left Plating: paso 4, imagen 1 de 2 Olympus Stylus Tough 6020 LCD Replacement, Left Plating: paso 4, imagen 2 de 2
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: paso 5, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: paso 5, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement, Black "Olympus" Face Plate: paso 5, imagen 3 de 3
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Olympus Stylus Tough 6020 LCD Replacement, End Casing: paso 6, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement, End Casing: paso 6, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement, End Casing: paso 6, imagen 3 de 3
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: paso 7, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: paso 7, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement, Blue Face Plate: paso 7, imagen 3 de 3
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Olympus Stylus Tough 6020 LCD Replacement, Back Plate: paso 8, imagen 1 de 1
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Olympus Stylus Tough 6020 LCD Replacement: paso 9, imagen 1 de 3 Olympus Stylus Tough 6020 LCD Replacement: paso 9, imagen 2 de 3 Olympus Stylus Tough 6020 LCD Replacement: paso 9, imagen 3 de 3
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
  10. Olympus Stylus Tough 6020 LCD Replacement, Ribbon Cables: paso 10, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, pull the white ribbon cable to disconnect it.
    • Using tweezers, pull the brown ribbon cable to disconnect it.
  11. Olympus Stylus Tough 6020 LCD Replacement, LCD Screen: paso 11, imagen 1 de 2 Olympus Stylus Tough 6020 LCD Replacement, LCD Screen: paso 11, imagen 2 de 2
    • Using the Phillips #00 Screwdriver, unscrew the 3.9mm screws on the back left side of the LCD screen case.
    • Using the spudger, gently pry the two screw holders from the LCD screen case.
    • Using your hands, gently push LCD through the LCD screen case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,027
