Saltar al contenido principal
Olympus Stylus 760 Case Replacement
Qué necesitas
  1. Olympus Stylus 760 Case Replacement, Case: paso 1, imagen 1 de 1
    • Remove the 2 screws from the bottom of the camera
  2. Olympus Stylus 760 Case Replacement: paso 2, imagen 1 de 1
    • Remove the screw from the right side of the camera.
  3. Olympus Stylus 760 Case Replacement: paso 3, imagen 1 de 1
    • Remove the two screws from the left side of the camera
  4. Olympus Stylus 760 Case Replacement: paso 4, imagen 1 de 3 Olympus Stylus 760 Case Replacement: paso 4, imagen 2 de 3 Olympus Stylus 760 Case Replacement: paso 4, imagen 3 de 3
    • Separate the front casing from the back using a plastic opening tool, gently.
    • Silver band and buttons will become loose when you remove the two pieces.
  5. Olympus Stylus 760 Case Replacement: paso 5, imagen 1 de 2 Olympus Stylus 760 Case Replacement: paso 5, imagen 2 de 2
    • Pull the silver bracket and buttons off of the camera
  6. Olympus Stylus 760 Case Replacement: paso 6, imagen 1 de 3 Olympus Stylus 760 Case Replacement: paso 6, imagen 2 de 3 Olympus Stylus 760 Case Replacement: paso 6, imagen 3 de 3
    • Remove the 2 screws on the right side of the camera.
    • Remove the 2 screws on the left side of the camera.
    • Circuit ribbon is attached at the top-left of the camera. Be careful when separating the front and back of the camera.
    • Pull the camera apart into 2 separate pieces.
  7. Olympus Stylus 760 Case Replacement: paso 7, imagen 1 de 1
    • Flip up clip on circuit ribbon, carefully
    • Detach the ribbon from the rear to the front and pull it out, gently.
  8. Olympus Stylus 760 Case Replacement: paso 8, imagen 1 de 1
    • You will be left with four major pieces
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 13
Todo El Tiempo: 600
