Saltar al contenido principal
Olympus Stylus 410 Speaker Replacement
Qué necesitas
  1. Olympus Stylus 410 Speaker Replacement, Outer Case: paso 1, imagen 1 de 3 Olympus Stylus 410 Speaker Replacement, Outer Case: paso 1, imagen 2 de 3 Olympus Stylus 410 Speaker Replacement, Outer Case: paso 1, imagen 3 de 3
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  2. Olympus Stylus 410 Speaker Replacement: paso 2, imagen 1 de 2 Olympus Stylus 410 Speaker Replacement: paso 2, imagen 2 de 2
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  3. Olympus Stylus 410 Speaker Replacement: paso 3, imagen 1 de 2 Olympus Stylus 410 Speaker Replacement: paso 3, imagen 2 de 2
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  4. Olympus Stylus 410 Speaker Replacement: paso 4, imagen 1 de 2 Olympus Stylus 410 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  5. Olympus Stylus 410 Speaker Replacement: paso 5, imagen 1 de 3 Olympus Stylus 410 Speaker Replacement: paso 5, imagen 2 de 3 Olympus Stylus 410 Speaker Replacement: paso 5, imagen 3 de 3
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  6. Olympus Stylus 410 Speaker Replacement: paso 6, imagen 1 de 1
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  7. Olympus Stylus 410 Speaker Replacement: paso 7, imagen 1 de 2 Olympus Stylus 410 Speaker Replacement: paso 7, imagen 2 de 2
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  8. Olympus Stylus 410 Speaker Replacement, Speaker: paso 8, imagen 1 de 3 Olympus Stylus 410 Speaker Replacement, Speaker: paso 8, imagen 2 de 3 Olympus Stylus 410 Speaker Replacement, Speaker: paso 8, imagen 3 de 3
    • Use a spudger to remove the speaker. It is attached by a double sided adhesive so it should just peel off.
  9. Olympus Stylus 410 Speaker Replacement: paso 9, imagen 1 de 1
    • Un-solder the wires to remove the speaker.
Conclusión
Equipo
Cal Poly, Team 6-13, Maness Spring 2010 Miembro de Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Miembros
17 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,415
