Saltar al contenido principal
Introducción
If the screen on your Olympus Stylus 410 is cracked and/or no longer works, use this repair guide to install a new one.
Partes
No se especificaron partes.
  1. Locate the 2 screws on the bottom of the slider.
    • Locate the 2 screws on the bottom of the slider.
    • Remove both screws with a #00 Phillips screwdriver.
  2. Gently pull on the bottom of the slider until it comes off the lower track.
    • Gently pull on the bottom of the slider until it comes off the lower track.
    • There is a little piece that connects the slider to the track. Be sure not to lose this as it is needed to put the slider back on.
  3. Lift the slider up until it comes off the upper track.
    • Lift the slider up until it comes off the upper track.
  4. The slider should now be free from the body of the camera.
    • The slider should now be free from the body of the camera.
  5. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver. Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
    • Locate the 3 screws on the outer metal band and remove them with a #00 Phillips screwdriver.
  6. Baterías para ordenadores portátiles
    Baterías para todas las mejores marcas de PC, respaldadas por nuestra Garantía de calidad.
    Comprar Ahora
    Comprar Ahora
  7. Use the spudger to peel off the outer metal band, starting from the bottom of the camera. The metal band it attached to the camera with glue in addition to screws.  Be careful not to bend the band when removing it from the camera.
    • Use the spudger to peel off the outer metal band, starting from the bottom of the camera.
    • The metal band it attached to the camera with glue in addition to screws. Be careful not to bend the band when removing it from the camera.
  8. The shutter button can now be removed. It is not connected to the camera and can be lifted off. The shutter button can now be removed. It is not connected to the camera and can be lifted off.
    • The shutter button can now be removed. It is not connected to the camera and can be lifted off.
  9. Remove the memory card. Locate and remove the 2 screws using a #00 Phillips screwdriver.
    • Remove the memory card.
    • Locate and remove the 2 screws using a #00 Phillips screwdriver.
  10. Use a spudger around the edge of the case to loosen it. Carefully wiggle the back case off. This may require a fair amount of force. Carefully wiggle the back case off. This may require a fair amount of force.
    • Use a spudger around the edge of the case to loosen it.
    • Carefully wiggle the back case off. This may require a fair amount of force.
  11. Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
    • Locate the 3 internal screws holding on the front of the case. Remove them with a #00 Phillips screwdriver.
  12. While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required. Be careful not to completely pull the front case off because it will still be connected with wires.
    • While grasping the interior and the front case, gently pull until they start to come apart. Some light wiggling may be required.
    • Be careful not to completely pull the front case off because it will still be connected with wires.
  13. Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger. Remove the metal frame from the LCD screen using a spudger.
    • Remove the metal frame from the LCD screen using a spudger.
  14. Pry off the LCD screen from the top using a spudger.  The screen will not be completely free from the device because of a ribbon. Do not pull the screen completely off because it will still be held on by two ribbon cables. Do not pull the screen completely off because it will still be held on by two ribbon cables.
    • Pry off the LCD screen from the top using a spudger. The screen will not be completely free from the device because of a ribbon.
    • Do not pull the screen completely off because it will still be held on by two ribbon cables.
  15. This is what the camera will look like now that the LCD screen is removed.
    • This is what the camera will look like now that the LCD screen is removed.
Conclusión
Rory Aronson
Miembro Desde 15/04/10
34 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 6-13, Maness Spring 2010 Miembro de Cal Poly, Team 6-13, Maness Spring 2010
CPSU-MANESS-S10S6G13
5 Miembros
9 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 3,706
