Saltar al contenido principal
Olympus Stylus 1030 SW AV Port Replacement
Qué necesitas
  1. Olympus Stylus 1030 SW AV Port Replacement, AV Port: paso 1, imagen 1 de 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: paso 1, imagen 2 de 3 Olympus Stylus 1030 SW AV Port Replacement, AV Port: paso 1, imagen 3 de 3
    • Use your screwdriver with a Phillips #00 screwdriver to remove all three screws.
    • Use your hand to lift and remove the front case.
  2. Olympus Stylus 1030 SW AV Port Replacement: paso 2, imagen 1 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 2, imagen 2 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 2, imagen 3 de 3
    • Remove the rear case.
    • Use a Phillips #00 screwdriver to remove both screws from the side panel.
    • Remove both screws from the battery door.
  3. Olympus Stylus 1030 SW AV Port Replacement: paso 3, imagen 1 de 1
    • Flip the Olympus Stylus 1030 SW camera upside down, the rear side facing away from you.
  4. Olympus Stylus 1030 SW AV Port Replacement: paso 4, imagen 1 de 2 Olympus Stylus 1030 SW AV Port Replacement: paso 4, imagen 2 de 2
    • Flip your camera with the rear side facing away from you. Take your screw driver with the #00 size to remove both screws.
    • Remove the front case.
  5. Olympus Stylus 1030 SW AV Port Replacement: paso 5, imagen 1 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 5, imagen 2 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 5, imagen 3 de 3
    • Start with the rear end facing away from you.
    • Use a Phillips #00 size to remove both screws.
    • Flip the camera to the front facing you.
    • Remove the single Phillips #00 screw.
  6. Olympus Stylus 1030 SW AV Port Replacement: paso 6, imagen 1 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 6, imagen 2 de 3 Olympus Stylus 1030 SW AV Port Replacement: paso 6, imagen 3 de 3
    • To get to the AV port use a spudger to separate the camera.
  7. Olympus Stylus 1030 SW AV Port Replacement: paso 7, imagen 1 de 2 Olympus Stylus 1030 SW AV Port Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the remaining two screws from the motherboard.
  8. Olympus Stylus 1030 SW AV Port Replacement: paso 8, imagen 1 de 2 Olympus Stylus 1030 SW AV Port Replacement: paso 8, imagen 2 de 2
    • Use your fingers to lift the black flap and use a Phillips #00 screwdriver to remove the two screws.
  9. Olympus Stylus 1030 SW AV Port Replacement: paso 9, imagen 1 de 2 Olympus Stylus 1030 SW AV Port Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • With your tweezers from your kit, take out the motherboard of the camera.
    • Once the motherboard is removed separate the motherboard.
    • The AV port is visible, use your spatula to wedge between the AV port to remove.
Conclusión
Alexis Sulzle
Miembro Desde 03/24/23
301 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 69
