Saltar al contenido principal
Olympus Stylus 1010 Lens Replacement
Qué necesitas
  1. Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: paso 1, imagen 1 de 2 Olympus Stylus 1010 Lens Replacement, Disassembling Olympus Stylus 1010 Case: paso 1, imagen 2 de 2
    • Remove the five Phillips #00 bottom and right side panel screws.
  2. Olympus Stylus 1010 Lens Replacement: paso 2, imagen 1 de 1
    • Remove the right side panel by pulling off the large silver piece.
  3. Olympus Stylus 1010 Lens Replacement: paso 3, imagen 1 de 2 Olympus Stylus 1010 Lens Replacement: paso 3, imagen 2 de 2
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Olympus Stylus 1010 Lens Replacement: paso 4, imagen 1 de 1
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Olympus Stylus 1010 Lens Replacement: paso 5, imagen 1 de 1
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Olympus Stylus 1010 Lens Replacement: paso 6, imagen 1 de 3 Olympus Stylus 1010 Lens Replacement: paso 6, imagen 2 de 3 Olympus Stylus 1010 Lens Replacement: paso 6, imagen 3 de 3
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
  7. Olympus Stylus 1010 Lens Replacement: paso 7, imagen 1 de 3 Olympus Stylus 1010 Lens Replacement: paso 7, imagen 2 de 3 Olympus Stylus 1010 Lens Replacement: paso 7, imagen 3 de 3
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
  8. Olympus Stylus 1010 Lens Replacement, Lens: paso 8, imagen 1 de 2 Olympus Stylus 1010 Lens Replacement, Lens: paso 8, imagen 2 de 2
    • Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
  9. Olympus Stylus 1010 Lens Replacement: paso 9, imagen 1 de 1
    • Remove the three screws from the inside of the camera using a #00 screwdriver.
  10. Olympus Stylus 1010 Lens Replacement: paso 10, imagen 1 de 2 Olympus Stylus 1010 Lens Replacement: paso 10, imagen 2 de 2
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
Conclusión
2 personas más completaron esta guía.
Max McIntyre
Miembro Desde 01/21/11
526 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 13-4, Forte Winter 2011 Miembro de Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 31
Todo El Tiempo: 5,929
