Introducción
This guide will help you to replace the flash device on your Olympus Stylus 1010.
Qué necesitas
Remove the five Phillips #00 bottom and right side panel screws.
Using a plastic spudger, lift up the black clips.
Still using the spudger, detach the three gold wire tape connectors from the inside of the camera.
Remove the two remaining Phillips #00 screws.
Lift the metal piece straight up to remove it.
Casi Terminas!
Conclusión
