Saltar al contenido principal
Olympus SZ-12 Lens Replacement
Qué necesitas
  1. Olympus SZ-12 Lens Replacement, Back Case: paso 1, imagen 1 de 2 Olympus SZ-12 Lens Replacement, Back Case: paso 1, imagen 2 de 2
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. Olympus SZ-12 Lens Replacement: paso 2, imagen 1 de 1
    • There are four screws to take out on the bottom of the camera.
  3. Olympus SZ-12 Lens Replacement: paso 3, imagen 1 de 1
    • There are three screws to take out on this side.
  4. Olympus SZ-12 Lens Replacement: paso 4, imagen 1 de 1
    • There is one screw to take out on this side.
  5. Olympus SZ-12 Lens Replacement: paso 5, imagen 1 de 1
    • There is one hidden screw inside the HDMI port.
  6. Olympus SZ-12 Lens Replacement: paso 6, imagen 1 de 1
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Olympus SZ-12 Lens Replacement, LCD Screen: paso 7, imagen 1 de 1
    • Once you have the back case off, remove the LCD Screen.
  8. Olympus SZ-12 Lens Replacement: paso 8, imagen 1 de 1
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Olympus SZ-12 Lens Replacement: paso 9, imagen 1 de 1
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
  10. Olympus SZ-12 Lens Replacement, Lens: paso 10, imagen 1 de 2 Olympus SZ-12 Lens Replacement, Lens: paso 10, imagen 2 de 2
    • Remove the four 3.8mm Phillips #000 screws from the LCD frame.
  11. Olympus SZ-12 Lens Replacement: paso 11, imagen 1 de 3 Olympus SZ-12 Lens Replacement: paso 11, imagen 2 de 3 Olympus SZ-12 Lens Replacement: paso 11, imagen 3 de 3
    • Remove the top left screw, top right screw, bottom left screw, and bottom right screw from LCD frame.
  12. Olympus SZ-12 Lens Replacement: paso 12, imagen 1 de 3 Olympus SZ-12 Lens Replacement: paso 12, imagen 2 de 3 Olympus SZ-12 Lens Replacement: paso 12, imagen 3 de 3
    • Lift the retaining flaps on the three remaining ZIF connectors connected to the motherboard.
  13. Olympus SZ-12 Lens Replacement: paso 13, imagen 1 de 1
    • Remove the five 4.3mm Phillips #000 screws from the lens frame to access the lens.
    • Remove the lens frame.
  14. Olympus SZ-12 Lens Replacement: paso 14, imagen 1 de 3 Olympus SZ-12 Lens Replacement: paso 14, imagen 2 de 3 Olympus SZ-12 Lens Replacement: paso 14, imagen 3 de 3
    • Remove two 4.3mm Phillips #000 screws from black plastic piece surrounding the lens.
    • Remove the lens.
Conclusión
3 personas más completaron esta guía.
Un comentario
Is her anything in the lens assembly that I could look for which may have dislodged showing up as a shadow on the bottom of the display screen
Deacon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 20
Todo El Tiempo: 1,867
