Introducción
In this guide you will learn to remove your camera's back case to expose the motherboard. While replacing the motherboard be very gentle. As you will see in the steps, there are internal ribbons that could easily be ripped or broken.
Qué necesitas
Remove the 3 mm long screws using a Phillips head screwdriver that has a PH000 size bit.
2 personas más completaron esta guía.
2 comentarios
Nice description to follow!
Would you know which component is responsible in SP-320 for keeping the date/time while battery is out ?
Every time I remove the battery for replacement, the date/time settings is gone (instantly). Thanks!
