Saltar al contenido principal
Olympus SP-320 Back casing and LCD screen Replacement
Qué necesitas
  1. Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: paso 1, imagen 1 de 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: paso 1, imagen 2 de 3 Olympus SP-320 Back casing and LCD screen Replacement, Back casing and LCD screen: paso 1, imagen 3 de 3
    • Remove the 3 mm long screws with a Phillips head screwdriver that has a PH000 size bit.
  2. Olympus SP-320 Back casing and LCD screen Replacement: paso 2, imagen 1 de 1
    • Remove the 3 mm long screw using Phillips head screwdriver that has a PH000 size bit.
  3. Olympus SP-320 Back casing and LCD screen Replacement: paso 3, imagen 1 de 1
    • Pry the outer case open using a blue, plastic opening tool.
    • Pry case open gently to avoid tearing the ribbon that connects the front part of the case to the back of the case.
  4. Olympus SP-320 Back casing and LCD screen Replacement: paso 4, imagen 1 de 3 Olympus SP-320 Back casing and LCD screen Replacement: paso 4, imagen 2 de 3 Olympus SP-320 Back casing and LCD screen Replacement: paso 4, imagen 3 de 3
    • Detach camera body from back casing and LCD screen.
    • Pull gently on the white connecting cable to detach it from the main body of the camera.
    • Lift the small, plastic clip, detaching the ribbon from the main body of the camera.
  5. Olympus SP-320 Back casing and LCD screen Replacement: paso 5, imagen 1 de 3 Olympus SP-320 Back casing and LCD screen Replacement: paso 5, imagen 2 de 3 Olympus SP-320 Back casing and LCD screen Replacement: paso 5, imagen 3 de 3
    • You have detached the back casing and LCD screen.
Conclusión
Un comentario
Is that thin white connector - a powercable to screen led-light? thnx
Alex CalmCroft Tokarsky - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 11
Todo El Tiempo: 515
