Introducción
This guide will show you how to replace the external lens assembly on the Olympus E-PL7.
We highly suggest you use a magnetic project mat or an organization tray. This camera has many different types of screws and keeping them organized is key to proper reassembly.
Qué necesitas
Turn the camera upside down.
Push the grey tab to the right to open the battery compartment.
Pull out the battery.
Use a Phillips #00 screwdriver to remove the four 6.3 mm screws from the lens mount.
Remove the lens mount with tweezers.
To reassemble your camera, follow these instructions in reverse order.
2 personas más completaron esta guía.
