Saltar al contenido principal
Olympus Pen E-PL7 LCD Screen Replacement
Qué necesitas
  1. Olympus Pen E-PL7 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the camera upside down.
    • Push the grey tab to the right to open the battery compartment.
    • Pull out the battery.
    • The battery is not shown in these photos.
  2. Olympus Pen E-PL7 LCD Screen Replacement, LCD Screen: paso 2, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.3 mm screws from the base of the LCD screen.
  3. Olympus Pen E-PL7 LCD Screen Replacement: paso 3, imagen 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: paso 3, imagen 2 de 2
    • Fully extend the LCD assembly.
  4. Olympus Pen E-PL7 LCD Screen Replacement: paso 4, imagen 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 4, imagen 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the two 2.2 mm Phillips screws located on the back of the LCD screen.
    • Use tweezers to remove the top LCD bracket.
  5. Olympus Pen E-PL7 LCD Screen Replacement: paso 5, imagen 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 5, imagen 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 1.4 mm screws from the back of the LCD screen.
    • Remove the LCD ribbon cable with a pair of tweezers.
    • The cover may fall off after the screws have been removed.
  6. Olympus Pen E-PL7 LCD Screen Replacement: paso 6, imagen 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 6, imagen 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Carefully lift the LCD screen up and away from the assembly.
    • Do not attempt to fully remove the screen, as it is attached to the assembly by a ribbon cable.
  7. Olympus Pen E-PL7 LCD Screen Replacement: paso 7, imagen 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: paso 7, imagen 2 de 2
    • Use tweezers to peel back the plastic cover.
  8. Olympus Pen E-PL7 LCD Screen Replacement: paso 8, imagen 1 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 8, imagen 2 de 3 Olympus Pen E-PL7 LCD Screen Replacement: paso 8, imagen 3 de 3
    • Use a spudger to flip back the black bar on the LCD Ribbon ZIF connector.
  9. Olympus Pen E-PL7 LCD Screen Replacement: paso 9, imagen 1 de 2 Olympus Pen E-PL7 LCD Screen Replacement: paso 9, imagen 2 de 2
    • Gently pull the ribbon cable out with tweezers.
  10. Olympus Pen E-PL7 LCD Screen Replacement: paso 10, imagen 1 de 1
    • Remove the LCD Screen.
Conclusión
6 personas más completaron esta guía.
Kelsea Weber
Miembro Desde 11/12/15
20,015 Reputación
32 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
141 Miembros
17,895 Guías creadas
7 comentarios
Magnifico
Great Work!!
apuntotres - Contestar
Where can I buy a replacement LCD screen?
Joshua Almeida - Contestar
You don't show the final part taking the glass away from outer and the board, as the screen replacements don't come with connector board
josollis - Contestar
@josollis: Thanks for the hint! I got the missing info from the E-P5 LCD exchange instructions (on ifixit).
Stephan Fagerer - Contestar
I have reassembled the unit after replacing the broken Ribbon, however my LCD images are inverted in normal mode not selfie mode. Do anyone know why ?
Thanks in advance
ah to lee - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 20
Ultimos 30 días: 112
Todo El Tiempo: 10,081
