Saltar al contenido principal
Olympus OM-D E-M10 Mark II Lens Replacement
  1. Olympus OM-D E-M10 Mark II Lens Replacement, Lens: paso 1, imagen 1 de 1
    • Press the black button located to the right of the camera lens when facing the front of the camera.
  2. Olympus OM-D E-M10 Mark II Lens Replacement: paso 2, imagen 1 de 1
    • Grasp the innermost ring on the lens, closest to the camera body, which can be located by the small red dot. This is the only ring that should not turn, unless the button specified in the previous step is held down.
  3. Olympus OM-D E-M10 Mark II Lens Replacement: paso 3, imagen 1 de 1
    • While holding down the button specified in step 1, begin turning the inner most ring, specified in step 2, counterclockwise until the camera lens becomes free from the camera body.
  4. Olympus OM-D E-M10 Mark II Lens Replacement: paso 4, imagen 1 de 1
    • Once the lens is free from the camera body, pull the lens completely away from the body to make sure the lens is truly free.
Conclusión
Channing Pezet
Miembro Desde 02/14/18
214 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 58
Todo El Tiempo: 4,008
