Saltar al contenido principal
Olympus OM-D E-M10 Mark II Battery Replacement
  1. Olympus OM-D E-M10 Mark II Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Open the battery door latch by moving the black button in the direction of the arrow, towards the camera screen.
    • To ensure that the battery door is properly in the closed position, listen for an audible click.
  2. Olympus OM-D E-M10 Mark II Battery Replacement: paso 2, imagen 1 de 1
    • Move the dark red latch towards the direction of the camera lens to release the battery from the camera.
    • Make sure the dark red latch blocks the battery from moving after placing the battery in the camera during reassembly.
  3. Olympus OM-D E-M10 Mark II Battery Replacement: paso 3, imagen 1 de 1
    • You can now remove the battery from the body of the camera and begin reassembly with your new battery.
Conclusión
To reassemble your device with your new battery, follow these instructions in reverse order.
Allen Anjal
Miembro Desde 09/27/16
341 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S5-G6, Eyestone Spring 2018 Miembro de USF Tampa, Team S5-G6, Eyestone Spring 2018
USFT-EYESTONE-S18S5G6
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 17
Ultimos 30 días: 91
Todo El Tiempo: 6,188
