Saltar al contenido principal
Olympus FE-210 LCD Screen Replacement
Qué necesitas
  1. Olympus FE-210 LCD Screen Replacement, Battery: paso 1, imagen 1 de 2 Olympus FE-210 LCD Screen Replacement, Battery: paso 1, imagen 2 de 2
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. Olympus FE-210 LCD Screen Replacement: paso 2, imagen 1 de 2 Olympus FE-210 LCD Screen Replacement: paso 2, imagen 2 de 2
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Olympus FE-210 LCD Screen Replacement, Front Casing: paso 3, imagen 1 de 3 Olympus FE-210 LCD Screen Replacement, Front Casing: paso 3, imagen 2 de 3 Olympus FE-210 LCD Screen Replacement, Front Casing: paso 3, imagen 3 de 3
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Olympus FE-210 LCD Screen Replacement: paso 4, imagen 1 de 3 Olympus FE-210 LCD Screen Replacement: paso 4, imagen 2 de 3 Olympus FE-210 LCD Screen Replacement: paso 4, imagen 3 de 3
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Olympus FE-210 LCD Screen Replacement, Rear Casing: paso 5, imagen 1 de 1
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  6. Olympus FE-210 LCD Screen Replacement: paso 6, imagen 1 de 3 Olympus FE-210 LCD Screen Replacement: paso 6, imagen 2 de 3 Olympus FE-210 LCD Screen Replacement: paso 6, imagen 3 de 3
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  7. Olympus FE-210 LCD Screen Replacement, LCD Screen: paso 7, imagen 1 de 2 Olympus FE-210 LCD Screen Replacement, LCD Screen: paso 7, imagen 2 de 2
    • Remove the two 2.7 mm screws using a #00 screwdriver.
    • After removing the screws the display will be free. Do not remove it. Like the rear case, there is a cord connecting it to the motherboard that must be disconnected first.
  8. Olympus FE-210 LCD Screen Replacement: paso 8, imagen 1 de 3 Olympus FE-210 LCD Screen Replacement: paso 8, imagen 2 de 3 Olympus FE-210 LCD Screen Replacement: paso 8, imagen 3 de 3
    • Using a spudger, lift the latch on the connector.
    • Remove the ribbon cord from its connector.
    • Remove the LCD from the rest of the camera.
Conclusión
4 personas más completaron esta guía.
Matt
Miembro Desde 01/25/11
826 Reputación
6 Guías creadas
Equipo
Cal Poly, Team 4-36, Regan Winter 2011 Miembro de Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
Miembros de 3
14 Guías creadas
Un comentario
Now need source for replacement screen thank you
Emile Crotteau - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 12
Ultimos 30 días: 29
Todo El Tiempo: 5,433
