Saltar al contenido principal
  1. Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove. Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Open the battery compartment and remove the 2 screws in the top of the opening. Open the battery compartment and remove the 2 screws in the top of the opening.
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Remove the 2 exposed screws on the bottom of the camera. Remove the 2 exposed screws on the bottom of the camera.
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Uncover the video cable port on the side of the camera and remove the screw
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera. Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  8. Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure. Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  9. Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels. Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
  10. Remove the three screws holding the outer circuit board in place. Remove the three screws holding the outer circuit board in place. Remove the three screws holding the outer circuit board in place.
    • Remove the three screws holding the outer circuit board in place.
  11. Use the spudger or your fingers to remove the outer circuit board from the camera. Use the spudger or your fingers to remove the outer circuit board from the camera.
    • Use the spudger or your fingers to remove the outer circuit board from the camera.
  12. Use the spudger to pull the plastic tabs shown off of the motherboard. Gently pull the plastic piece off of the motherboard. Gently pull the plastic piece off of the motherboard.
    • Use the spudger to pull the plastic tabs shown off of the motherboard.
    • Gently pull the plastic piece off of the motherboard.
  13. Remove the screws shown using the 00 philips screwdriver. Remove the screws shown using the 00 philips screwdriver. Remove the screws shown using the 00 philips screwdriver.
    • Remove the screws shown using the 00 philips screwdriver.
  14. Use the pointed end of the spudger to release the ribbon cable clasp. Remove the ribbon cable from the port using the tweezers. Remove the ribbon cable from the port using the tweezers.
    • Use the pointed end of the spudger to release the ribbon cable clasp.
    • Remove the ribbon cable from the port using the tweezers.
  15. Use the tweezers to remove the ribbon cable near the shutter button.
    • Use the tweezers to remove the ribbon cable near the shutter button.
  16. Next unsolder the connections shown.
    • Next unsolder the connections shown.
    • See our soldering guide for help on how to unsolder
    • Soldering irons are hot, and will also heat the connection wire. Using the tweezers will protect your fingers from the heat.
  17. Gently pull the motherboard (from the bottom first) away from the device. Gently pull the motherboard (from the bottom first) away from the device. Gently pull the motherboard (from the bottom first) away from the device.
    • Gently pull the motherboard (from the bottom first) away from the device.
  18. Remove the 3 screws holding the lens assembly in place. Remove the 3 screws holding the lens assembly in place. Remove the 3 screws holding the lens assembly in place.
    • Remove the 3 screws holding the lens assembly in place.
  19. Gently remove the lens assembly by pulling on the top of the assembly first, then removing from the device. Gently remove the lens assembly by pulling on the top of the assembly first, then removing from the device. Gently remove the lens assembly by pulling on the top of the assembly first, then removing from the device.
    • Gently remove the lens assembly by pulling on the top of the assembly first, then removing from the device.
Conclusión
CCrane
Miembro Desde 26/03/15
201 Reputación
2 Guías creadas
Equipo
Baylor, Team 6-4, Shaver Spring 2015 Miembro de Baylor, Team 6-4, Shaver Spring 2015
BU-SHAVER-S15S6G4
3 Miembros
6 Guías creadas
Añadir comentario
Ver Estadísticas:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
Global: 285
