Saltar al contenido principal
Olympus E-Pl1 Speaker Replacement
Qué necesitas
  1. Olympus E-Pl1 Speaker Replacement, Opening The Case: paso 1, imagen 1 de 1
    • Push the gray tab down, using a spudger if necessary, and the battery will come out.
    • Failure to remove the battery prior to disassembly can result in harm.
  2. Olympus E-Pl1 Speaker Replacement: paso 2, imagen 1 de 3 Olympus E-Pl1 Speaker Replacement: paso 2, imagen 2 de 3 Olympus E-Pl1 Speaker Replacement: paso 2, imagen 3 de 3
    • There are a total of six screws that must be removed using the the #000 Philips screwdriver.
    • As per picture one: there is one 4.9 mm Philips head screw on the left side of the camera.
    • As per picture two: on the bottom of the camera, there are three 3.4 mm Philips head screws; these are located on the darker area of the case.
    • As per picture three: there are two 5.3 mm Philips head screws on the right side, one is beneath the USB cover.
  3. Olympus E-Pl1 Speaker Replacement: paso 3, imagen 1 de 1
    • Open the case by peeling off the back panel.
    • Pull the case apart gently so that the ribbon connector will not tear.
  4. Olympus E-Pl1 Speaker Replacement: paso 4, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement: paso 4, imagen 2 de 2
    • Disconnect the two ribbon cables as shown in picture one.
    • Avoid using metal pry tools, as shown in the photo, on internal electronic components, as it can cause a short and damage the device. Use an ESD-safe tool such as a standard nylon spudger.
    • To disconnect a ribbon cable, use a spudger to lift the black tab then pull the ribbon out. This works the same for all ribbon cables.
  5. Olympus E-Pl1 Speaker Replacement: paso 5, imagen 1 de 1
    • The back panel has now been removed.
  6. Olympus E-Pl1 Speaker Replacement, LCD Screen: paso 6, imagen 1 de 3 Olympus E-Pl1 Speaker Replacement, LCD Screen: paso 6, imagen 2 de 3 Olympus E-Pl1 Speaker Replacement, LCD Screen: paso 6, imagen 3 de 3
    • As per picture one: peel back the black strip.
    • As per picture two: peel back the Copper strip.
    • As per picture three: peel back the blue tape.
  7. Olympus E-Pl1 Speaker Replacement: paso 7, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement: paso 7, imagen 2 de 2
    • There are four screws that need to be removed using the #000 Philips screwdriver.
    • Remove the three 3.4 mm screws on the silver panel.
    • Now remove the 4.3 mm screw located on the green board.
  8. Olympus E-Pl1 Speaker Replacement: paso 8, imagen 1 de 1
    • Lift out and remove the metal plating over the LCD screen.
  9. Olympus E-Pl1 Speaker Replacement: paso 9, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use a spudger to lift the brown lock tab.
    • Using tweezers, lift the ribbon cable from the brown lock tab.
  10. Olympus E-Pl1 Speaker Replacement: paso 10, imagen 1 de 1
    • Lift out the LCD Screen.
  11. Olympus E-Pl1 Speaker Replacement, Speaker: paso 11, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement, Speaker: paso 11, imagen 2 de 2
    • Using a spudger lift up the black retainer tab.
    • Gently pull out the ribbon cable.
  12. Olympus E-Pl1 Speaker Replacement: paso 12, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement: paso 12, imagen 2 de 2
    • Using your fingers, grab the copper grounding strip and blue and black tape.
    • Pull these three back at the same time.
  13. Olympus E-Pl1 Speaker Replacement: paso 13, imagen 1 de 2 Olympus E-Pl1 Speaker Replacement: paso 13, imagen 2 de 2
    • Using a #000 Phillips screwdriver remove the four 3.7 mm screws holding the board.
    • Using a #000 Phillips screwdriver remove the 4.3 mm screw as shown in picture two as well as the clear plastic sheet.
  14. Olympus E-Pl1 Speaker Replacement: paso 14, imagen 1 de 1
    • Gently lift out the board being careful of the wires in the center
  15. Olympus E-Pl1 Speaker Replacement: paso 15, imagen 1 de 1
    • With your fingers twist and move the speaker to the other side of the board.
  16. Olympus E-Pl1 Speaker Replacement: paso 16, imagen 1 de 1
    • Using a soldering iron and soldering wick desolder the two wires connecting the speaker
    • The new speaker must be attached with the wire colors in the same orientation.
    • Solder in the new speaker. Be sure to match the wire color to the original wire placement.
Conclusión
Jeffery Smith
Miembro Desde 03/11/15
748 Reputación
6 Guías creadas
Equipo
Un comentario
Dear Jeffery,
thank you very much for this nice tutorial.
Could you please tell us the part number of the speaker you exchanged?
Can’t see the upper part of the number on the pictures: ???1710
Thank you
Sincerely
Lears
Lars Hooge - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 19
Todo El Tiempo: 1,093
