Introducción
This guide requires you to handle sharp metal objects. Proceed with caution. To avoid misplacing the screws hold them in place with masking tape. Make sure your hands are clean and dry before they come in contact with the internal parts of the camera.
Qué necesitas
Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
Using the PH000 screwdriver, remove the two 4mm screws located on the left side of the camera, under the strap holder.
4 personas más completaron esta guía.
2 comentarios
Bravo super tutorial, but how to ensure the sealing after disassembly and reassembly?
I have a problem recovering the original condition. Is it possible Someone help me to restore it. Olympus TG-3 contact back. Witrocker@hotmail.com
