Saltar al contenido principal
Olympus Digital Camera TG-3 Front Case Replacement
Qué necesitas
  1. Olympus Digital Camera TG-3 Front Case Replacement, Front Case: paso 1, imagen 1 de 1
    • Locate the strap eyelet side of the camera and use the PH000 screwdriver to remove the two 5.3mm screws that hold the strap.
  2. Olympus Digital Camera TG-3 Front Case Replacement: paso 2, imagen 1 de 1
    • Locate the side of the camera containing the HDMI port. Use the PH000 screwdriver to remove the 5.4mm screw located on the lower left side below the port.
  3. Olympus Digital Camera TG-3 Front Case Replacement: paso 3, imagen 1 de 1
    • Using the PH000 screwdriver, remove the 3.8mm screw located inside the HDMI port.
  4. Olympus Digital Camera TG-3 Front Case Replacement: paso 4, imagen 1 de 1
    • Locate the bottom section of the camera. Using the PH000 screwdriver, remove the two 4mm screws located towards the middle (near the battery compartment).
  5. Olympus Digital Camera TG-3 Front Case Replacement: paso 5, imagen 1 de 1
    • Now you should be able to remove the front case easily using your hand.
Conclusión
Natalia Morales
Miembro Desde 10/11/16
675 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-6, Leahy Fall 2016 Miembro de USF Tampa, Team 1-6, Leahy Fall 2016
USFT-LEAHY-F16S1G6
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 1,001
