Saltar al contenido principal
Introducción
This guide shows how to replace a broken retainer clip (the plastic piece that covers the battery and XD card slot).
Partes
No se especificaron partes.
  1. Flip camera so you are looking at the bottom.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Unscrew the single screw located next to the battery slot.
    • Unscrew the single screw located next to the battery slot.
  4. Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  6. Unscrew the 2 screws next to the USB and AC ports.
    • Unscrew the 2 screws next to the USB and AC ports.
  7. Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  8. Pull off the faceplate to reveal the inside of the camera.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
  9. Orient the camera as shown, with the bottom facing up.
    • Orient the camera as shown, with the bottom facing up.
    • Open the retainer clip, by using your finger to push down and slide to the left.
    • The clip should pop open.
  10. Hold the retainer clip down (without re-latching it).
    • Hold the retainer clip down (without re-latching it).
    • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
  11. Use tweezers to continue to remove the pin.
    • Use tweezers to continue to remove the pin.
  12. When it feels loose, pull the pin all the way out with your fingers.
    • When it feels loose, pull the pin all the way out with your fingers.
  13. Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
    • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
Conclusión
Katie
Miembro Desde 15/04/10
25 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 2,061
