Saltar al contenido principal
Olympus D590 Retainer Clip Replacement
Qué necesitas
  1. Olympus D590 Retainer Clip Replacement, Face Plate: paso 1, imagen 1 de 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Retainer Clip Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Retainer Clip Replacement: paso 3, imagen 1 de 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Retainer Clip Replacement: paso 4, imagen 1 de 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Retainer Clip Replacement: paso 5, imagen 1 de 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Retainer Clip Replacement: paso 6, imagen 1 de 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Retainer Clip Replacement: paso 7, imagen 1 de 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Retainer Clip Replacement, Retainer Clip: paso 8, imagen 1 de 1
    • Orient the camera as shown, with the bottom facing up.
    • Open the retainer clip, by using your finger to push down and slide to the left.
    • The clip should pop open.
  9. Olympus D590 Retainer Clip Replacement: paso 9, imagen 1 de 1
    • Hold the retainer clip down (without re-latching it).
    • Use a flathead screwdriver to start to pry out the pin holding the retainer clip's spring to the camera.
  10. Olympus D590 Retainer Clip Replacement: paso 10, imagen 1 de 1
    • Use tweezers to continue to remove the pin.
  11. Olympus D590 Retainer Clip Replacement: paso 11, imagen 1 de 1
    • When it feels loose, pull the pin all the way out with your fingers.
  12. Olympus D590 Retainer Clip Replacement: paso 12, imagen 1 de 1
    • Once the pin comes out, the retainer clip, spring, and pin will no longer be attached to the rest of the camera.
Conclusión
Katie
Miembro Desde 04/15/10
31 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
Miembros de 4
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 2,216
