Introducción
This guide shows how to replace the camera lens and surrounding mechanisms (including the motor).
Partes
No se requieren partes.
  1. Flip camera so you are looking at the bottom.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Unscrew the single screw located next to the battery slot.
    • Unscrew the single screw located next to the battery slot.
  4. Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Unscrew the 2 screws next to the USB and AC ports.
    • Unscrew the 2 screws next to the USB and AC ports.
  6. Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  7. Pull off the faceplate to reveal the inside of the camera.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
  8. Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
    • Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
  9. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  10. Unscrew the 2 screws located on either side of the flash.
    • Unscrew the 2 screws located on either side of the flash.
  11. Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Carefully pry off the blackplate from the remaining part of the camera.
  12. Pull the backplate off.
    • Pull the backplate off.
  13. Unscrew the screw shown in the picture from LCD screen.
    • Unscrew the screw shown in the picture from LCD screen.
  14. Remove the side pannel by sliding it off the body of the camera. Lift the camera no more than 3cm to make sure all screws have been taken off.
    • Remove the side pannel by sliding it off the body of the camera.
    • Lift the camera no more than 3cm to make sure all screws have been taken off.
  15. Flip camera so you are looking at the front. Remove gray and blue wiring with tweasers by gently wiggling and pulling.
    • Flip camera so you are looking at the front.
    • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
    • Be careful not to rip the wiring tape with the tweezers.
  16. Locate the tape securing the wiring with the gray end piece located on top of the camera. Gently lift up on the tape till all wires are exposed.
    • Locate the tape securing the wiring with the gray end piece located on top of the camera.
    • Gently lift up on the tape till all wires are exposed.
  17. Flip Camera to the bottom side as shown.
    • Flip Camera to the bottom side as shown.
    • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
  18. Flip camera so the front is facing you. Locate speaker in upper right hand corner. Gently lift with tweasers.
    • Flip camera so the front is facing you.
    • Locate speaker in upper right hand corner.
    • Gently lift with tweasers.
    • Feed wiring through designated spot so that it is no longer connected to the camera.
  19. Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera. Gently pull the thick yellow wiring out by using the forefinger and thumb.
    • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
    • Gently pull the thick yellow wiring out by using the forefinger and thumb.
  20. Flip camera so you are looking at the back.
    • Flip camera so you are looking at the back.
    • Remove the 3 screws from the rear of the camera behind the lens.
  21. Flip camera so the front lens is facing up.
    • Flip camera so the front lens is facing up.
    • Unplug lens from logic board.
  22. Flip camera over so the lens is facing down and the back of the camera is facing you.
    • Flip camera over so the lens is facing down and the back of the camera is facing you.
    • Gently pull back on the wire that connects logic board to lens assembly so it is no longer connected.
  23. Flip camera so the front is facing you.
    • Carefully lift lens assembly out of camera.
Conclusión
Joshua
Miembro Desde 15/04/10
7 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 2,354
