Saltar al contenido principal
Introducción
Removal of the front plate to get into the logic board, lens, etc.
Partes
No se especificaron partes.
  1. Flip camera so you are looking at the bottom.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Unscrew the single screw located next to the battery slot.
    • Unscrew the single screw located next to the battery slot.
  4. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  5. Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  6. Unscrew the 2 screws next to the USB and AC ports.
    • Unscrew the 2 screws next to the USB and AC ports.
  7. Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  8. Pull off the faceplate to reveal the inside of the camera.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
Conclusión
Katie
Miembro Desde 15/04/10
25 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,503
