Saltar al contenido principal
Introducción
The guide shows how to remove the backplate of the camera. It is a prerequisite to other guides such as replacing the mic, speaker, LCD screen, and lens.
  1. Flip camera so you are looking at the bottom.
    • Flip camera so you are looking at the bottom.
    • Unscrew all 5 base plate screws.
  2. Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
    • Lift open retainer clip by sliding the clip to the left and letting the clip pop up.
  3. Unscrew the single screw located next to the battery slot.
    • Unscrew the single screw located next to the battery slot.
  4. Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Turn the camera so that the USB, AV and DC in/out rubber plate it facing you.
    • Lift the rubber plate exposing the ports beneath.
  5. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  6. Unscrew the 2 screws next to the USB and AC ports.
    • Unscrew the 2 screws next to the USB and AC ports.
  7. Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
    • Use a flathead screwdriver or another flat opening tool to pry the faceplate from the whole device.
  8. Pull off the faceplate to reveal the inside of the camera.
    • Pull off the faceplate to reveal the inside of the camera.
    • Be careful of the connector that goes from the faceplate to the motherboard . Disconnecting this line will cause the camera not not power on through the on/off switch anymore.
  9. Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
    • Use a phillips head screwdriver to remove the 3 screws highlighted in the picture.
  10. Unscrew the 2 screws located on either side of the flash.
    • Unscrew the 2 screws located on either side of the flash.
  11. Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Get a flathead screwdriver or an iPod opening tool (both are shown in this picture).
    • Carefully pry off the blackplate from the remaining part of the camera.
  12. Pull the backplate off.
    • Pull the backplate off.
Conclusión
Katie
Miembro Desde 15/04/10
25 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,939
