Saltar al contenido principal
Olympus D590 Backplate Replacement
Qué necesitas
  1. Olympus D590 Backplate Replacement, Face Plate: paso 1, imagen 1 de 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Backplate Replacement: paso 2, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Backplate Replacement: paso 3, imagen 1 de 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Backplate Replacement: paso 4, imagen 1 de 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Backplate Replacement: paso 5, imagen 1 de 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Backplate Replacement: paso 6, imagen 1 de 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Backplate Replacement: paso 7, imagen 1 de 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
  8. Olympus D590 Backplate Replacement, Backplate: paso 8, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove three screws fastened to the camera backplate edge.
  9. Olympus D590 Backplate Replacement: paso 9, imagen 1 de 1
    • Using a Phillips #00 screwdriver, remove the two camera flash screws secured to either side of bulb housing component.
  10. Olympus D590 Backplate Replacement: paso 10, imagen 1 de 1
    • Using an iFixit opening tool, pry the backplate from the camera internal housing component.
  11. Olympus D590 Backplate Replacement: paso 11, imagen 1 de 1
    • Pull the backplate away from the camera internal housing component.
Conclusión
Katie
Miembro Desde 04/15/10
31 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 28-23, Regan Spring 2010 Miembro de Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
Miembros de 4
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 8
Todo El Tiempo: 2,083
