Saltar al contenido principal
Olympus Camedia D560 Rear Panel Control Buttons Replacement
Qué necesitas
  1. Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: paso 1, imagen 1 de 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement, Rear Panel Control Buttons: paso 1, imagen 2 de 2
    • Before disassembling your camera, be sure it is powered off.
    • Remove two screws from the video port located at the side panel of the camera.
    • Remove three screws from the bottom panel of the camera.
  2. Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 2, imagen 1 de 2 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 2, imagen 2 de 2
    • Open the USB port cover, and remove three screws from inside.
    • Next, open the memory slot cover and remove the screw.
  3. Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 3, imagen 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 3, imagen 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 3, imagen 3 de 3
    • Use the blue opening tool to loosen and separate the back cover from the camera.
  4. Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 4, imagen 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 4, imagen 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 4, imagen 3 de 3
    • Locate and unscrew the three screws inside the back cover body (picture 3) .
    • Remove button pad assembly from the back cover.
  5. Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 5, imagen 1 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 5, imagen 2 de 3 Olympus Camedia D560 Rear Panel Control Buttons Replacement: paso 5, imagen 3 de 3
    • The button assembly is now separate from the back cover.
    • Inspect for broken areas. Replace or clean the button parts.
Conclusión
2 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 1,062
