Saltar al contenido principal
Olympus Camedia D560 LCD Screen Replacement
Qué necesitas
  1. Olympus Camedia D560 LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 2 Olympus Camedia D560 LCD Screen Replacement, LCD Screen: paso 1, imagen 2 de 2
    • Unscrew all immediately visible screws on the body of the camera.
    • Locations (# of screws): Bottom of camera (3), left side near video port (2), under cover of USB slot (3), memory card slot (1).
  2. Olympus Camedia D560 LCD Screen Replacement: paso 2, imagen 1 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 2, imagen 2 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to separate the back cover from the camera.
  3. Olympus Camedia D560 LCD Screen Replacement: paso 3, imagen 1 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 3, imagen 2 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 3, imagen 3 de 3
    • With the back plate off, locate two screws: one diagonal from the top left of the LCD screen and one diagonal from the top right of the LCD screen.
    • Unscrew both of these screws.
  4. Olympus Camedia D560 LCD Screen Replacement: paso 4, imagen 1 de 1
    • Flip the LCD screen over.
  5. Olympus Camedia D560 LCD Screen Replacement: paso 5, imagen 1 de 1
    • Undo the clip holding the ribbon cable that attaches the LCD screen to the motherboard.
  6. Olympus Camedia D560 LCD Screen Replacement: paso 6, imagen 1 de 2 Olympus Camedia D560 LCD Screen Replacement: paso 6, imagen 2 de 2
    • Unclip the plug attached to the red and white wires that connects the LCD screen to the motherboard.
  7. Olympus Camedia D560 LCD Screen Replacement: paso 7, imagen 1 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 7, imagen 2 de 3 Olympus Camedia D560 LCD Screen Replacement: paso 7, imagen 3 de 3
    • The LCD screen housing should now be free of the camera.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 1,308
