Introducción
Use this guide to replace a malfunctioning motherboard in the Olympus C-765.
The motherboard is a large, printed circuit board that controls all of the camera’s functions. A malfunctioning motherboard may be responsible for overall defunct camera operations. When a motherboard is bad, a camera may display a variety of errors, may function slowly, or may fail to start up at all. If the board is malfunctioning, it must be replaced in order to restore the camera to working order.
Be sure to consult the Troubleshooting guide before attempting to replace the motherboard. A slow camera may simply be solved by a system reset. A replacement only needs to be attempted if the reset does not work.
This guide will demonstrate how to complete this replacement process. The process involves multiple steps, including difficult steps like soldering.
Qué necesitas
Use a Phillips #00 screwdriver to remove the single 4mm screw located directly to the right of the viewfinder on the back of the camera.
Remove the two 2mm screws from the left side panel.
Remove the single 3mm screw from the right side panel.
Remove the five 3mm screws from the bottom of the camera.
Remove the ribbon cable directly below the viewfinder.
Detach the white plastic clip from its socket with a pair of tweezers.
Disconnect the ribbon cable from the center of the board, near the central hole.
Disconnect the three ribbon cables from the top right of the motherboard, near the selector wheel. One is on the top of the board, and the other two are on the underside.
